Autorius Tema: Master Patch  (Skaityta 49476 kartus)
  • Atomic
Neprisijungęs Progressiver
CX65 SW50
Ats.: Master Patch
« Atsakymas #80 Įrašytas: Liepos 03, 2006, 07:23 »
o sitas ka daro?
;* MyStuff = Disk Menu v0.1 *
; (p) LinuXrULz
0A4F92A: 0C 04
0A4F92C: 32 31
0A4F932: 43 00
0A4F954: 0C 04
0A4F95C: 43 00
niekur nerandu kad galima butu pasirinkt diska
reikia specialaus mystuff su disku meniu
gAL KAS LINKA GALI NUMEST TO SPEC MYSTUFF MENU KAD BUTU SU DISK'AIS?
Neprisijungęs NForce
Ats.: Master Patch
« Atsakymas #81 Įrašytas: Liepos 03, 2006, 10:41 »
aisku
jei nesunku gal gali imest savo telefo wallpaperi ar visa them'a?
siuskis
  • EL71v45
Ats.: Master Patch
« Atsakymas #82 Įrašytas: Liepos 03, 2006, 10:43 »
jap sw perrasymas + "clear sw from old patches" patchas
Būk žmogus įmesk, nes šiandien jau nėr noro ką nors pačiam daryt;) kitą kart kaip nors aš tau pagelbėsiu O|-) pas mane CX65 SW50, jei reikia...
;x65 - Clear firmware from old patches
;(c) avkiev
;Apply this patch immediately after installing new firmware (with creating Recovery Patch)
#pragma enable old_equal_ff
0800000: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0800100: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0800200: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0800300: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0800400: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0800500: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0800600: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0800700: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0800800: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0800900: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0800A00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0800B00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0800C00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0800D00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0800E00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0800F00: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0801000: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0801100: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0801200: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0801300: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0801400: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0801500: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0801600: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
0801700: FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
#pragma disable old_equal_ff
  • EL71v45
Ats.: Master Patch
« Atsakymas #83 Įrašytas: Liepos 03, 2006, 10:46 »
o sitas ka daro?
; (p) LinuXrULz
0A4F92A: 0C 04
0A4F92C: 32 31
0A4F932: 43 00
0A4F954: 0C 04
0A4F95C: 43 00
Tik issiversi i lt klaba ;)
  • EL71v45
Neprisijungęs Sxcool
Įrašai: 95 | Karma: +1/-3 | Lytis: Vyras
4 kreditai Žiūrėti inventorių Siųsti pinigus Sxcool
Just do it... :D
Ats.: Master Patch
« Atsakymas #84 Įrašytas: Liepos 07, 2006, 15:29 »
Kodėl, kai aš bandau užmest tą patch'ą man išmeta tokį error'a?
  • Atomic
CX65 SW50
Ats.: Master Patch
« Atsakymas #85 Įrašytas: Liepos 10, 2006, 11:48 »
o sitas ka daro?
; (p) LinuXrULz
0A4F92A: 0C 04
0A4F92C: 32 31
0A4F932: 43 00
0A4F954: 0C 04
0A4F95C: 43 00
lb dekui uz meniu tik gal galima suzinot kur jy idet? ;D
Neprisijungęs FanatMF
Įrašai: 15 | Karma: +2/-0
0 kreditai Žiūrėti inventorių Siųsti pinigus FanatMF
Ats.: Master Patch
« Atsakymas #86 Įrašytas: Liepos 10, 2006, 11:57 »
3:/Default/MyStuff
  • Atomic
CX65 SW50
Ats.: Master Patch
« Atsakymas #87 Įrašytas: Liepos 10, 2006, 14:13 »
noretum  :'( irasau patcha, padarau ta folderi sudedu failus, restert ir nieko!!!  :'(
Ats.: Master Patch
« Atsakymas #88 Įrašytas: Liepos 10, 2006, 15:25 »
Reiskia kazka blogai darai nes sitas bajeris tikrai veikia. pabandyk perrasyt is naujo mystuff.xml faila su proge mscx65
  • Atomic
CX65 SW50
Ats.: Master Patch
« Atsakymas #89 Įrašytas: Liepos 10, 2006, 16:47 »
bandaw  ;D nu ir nieko neveikia!!!  >:( sudedu my sutff=disk menu
poto dar disk selection menu ir tuos daiktus!! neveikia  >:(
« Paskutinį kartą keitė: Liepos 10, 2006, 17:00 sukūrė Progressiver »
Ats.: Master Patch
« Atsakymas #90 Įrašytas: Liepos 11, 2006, 07:49 »
o bent tos icon pasikeicia?
  • Atomic
CX65 SW50
Ats.: Master Patch
« Atsakymas #91 Įrašytas: Liepos 11, 2006, 09:01 »
nepasikeicia
Ats.: Master Patch
« Atsakymas #92 Įrašytas: Liepos 11, 2006, 12:17 »
tai sakau perrasyk mystuff.xml is naujo
  • EL71v45
  • Atomic
CX65 SW50
Ats.: Master Patch
« Atsakymas #93 Įrašytas: Liepos 12, 2006, 11:25 »
o ka as padariau jau kiek kartu?!  >:(
Ats.: Master Patch
« Atsakymas #94 Įrašytas: Liepos 12, 2006, 18:02 »
as sakau ne is naujo permesk i tel o perrasyk rankom mystuff.xml faila  >:(
  • EL71v45
  • Atomic
CX65 SW50
Ats.: Master Patch
« Atsakymas #95 Įrašytas: Liepos 14, 2006, 12:23 »
nemoku as ten tokias jeroglifais drozt  ;D
Ats.: Master Patch
« Atsakymas #96 Įrašytas: Liepos 14, 2006, 19:46 »
  • EL71v45
Neprisijungęs SN_Well
Įrašai: 14 | Karma: +1/-0
0 kreditai Žiūrėti inventorių Siųsti pinigus SN_Well
Ats.: Master Patch
« Atsakymas #97 Įrašytas: Liepos 18, 2006, 07:26 »
O tas patch "Clear firmware from old patches" netinka CX70? Nes niekur for CX70 nerandu :(
  • Atomic
CX65 SW50
Ats.: Master Patch
« Atsakymas #98 Įrašytas: Liepos 21, 2006, 09:30 »
OMG!!!  :o ziaurei dekuj  :-*
Ats.: Master Patch
« Atsakymas #99 Įrašytas: Liepos 24, 2006, 08:06 »
sn well tas patch tinka visiem sgold siemensam
  • EL71v45
